0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#739055 04/14/2011 5:21 AM
Hello everyone-im proud to be a member here.I am in negotiations to by my first stovebolt.It is a 59 Viking long wheel base.I want to make this a hardcore pickup truck basically and want to know if a long wheel base fleetside bed will fit this frame,in its previous life it served as a dump truck.I will post pics as soon as truck is delivered!
PatinaFiend #739069 04/14/2011 6:16 AM
welcome to the garage Fiend .... need better ID on the model, a Viking could be a 4, 5, or 6000 series and could have a WB of up to 174" - the long fleet [3200 series] WB is 123", and while there's a 5300 series that has a WB of 124" it doesn't sound like that's what you have .... so not likely
squeeze #739236 04/14/2011 10:16 PM
its a c-40 ton and a half im assuming its long wheel base-used to be a dump-just have to figure out how to get her home to Texas now
PatinaFiend #739244 04/14/2011 10:49 PM
i stand corrected its 4b59k 06790 a chevy 440 1.5 ton from kansas city,mo
PatinaFiend #739315 04/15/2011 2:57 AM
PF,
Welcome!
You serial number breaks down as follows:
4b59k 06790
4B = 4400 Series Designation
59 = 1959
K = Kansas City Assembly Plant
06790 = Unit number starting with 100001 (looks like you missed a 1 in front of the zero, not enough digits).
The 4400 has a 156.5" wheelbase. The Cab and Chassis (no bed on the truck) will have a curb weight of 4600 pounds.
You could load it on a HD car trailer and pull it with a full size pickup truck. I've done this many times...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #739585 04/16/2011 2:21 AM
Great info Mike,,thanks! What i really want to know is if i can put a regular pickup bed on it,,currently its just a cab and a frame.I want to make it into a badass pickup with a fifth wheel so i can haul a gooseneck with it
PatinaFiend #739596 04/16/2011 3:05 AM
welcome man, i was able to put the half ton bed on, but it required quite a bit of shortening to the frame. good luck on your build. -DVZ
