| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Hey guys, I need to know if your '60-'62 trucks have a hole in the front of the frame rail, behind the bumper, on the underside (side toward the ground) of the rail. This is in the area where a sway bar would mount.
My Suburban has matching holes on each side of the chassis, 10 inches back from the bottom edge of the front bumper. I just need to know if they all do.
Thanks, -Brad
SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | burbs and panels of all years had front [anti]sway bars
Bill | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | not all as my 64 4 x 4 panel did not come with one. ron | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | My '61 didn't have one either. And I've never seen a '60-66 truck in the junkyard, pick-up or panel, that had a factory front sway bar.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | I have a factory swaybar in my 65 Brad. I could find a pic for ya'. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Yeah, I'd like to see one. I've seen them on '67-up, but never the earlier ones.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | do y'all have assembly manuals? should show in there if/what models had them, the 55-59's all do and the AD's I've seen have'em - they might have changed later  Bill | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Neat. Thanks.
That one won't work on a '60-62 though, because of the way it mounts on the lower control arm.
Still looking for someone with a '60-'62 to see if that hole is in all the frames.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | the only 60-66 truck/panel/burb I've ever seen with a factory sway bar was a 66 Custom Camper 20, also only thing assy manual shows as having one standard. | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | My 61 3/4 ton has a set of 3/8 holes. I didn't measure, but it looks about 10 inches back | | |
