| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | I just replaced my king pins and found the right side lock pin was broken and the steering stop missing. First, Is there a steering stop on both sides? I checked a couple parts suppliers and did not see any.
Dave www.fallenherosdreamride.orgall give some MY SON GAVE ALL The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216 In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Yes - there are steering stops on both sides held in place by the lock pins that hold the king pin in place. It's easy enough to make. Get a piece of 1/4" thick angle and, using the other stop as a pattern cut it down to size to match. Drill a hole for the lock pin and you're done. | | |
