0 members (), 151 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#738902 04/13/2011 8:18 PM
I have a 36 and wanted to know if the rearend (torque tube) was the same for both trucks! I know mine is a 207 and the 37 is a 216 but i am pretty sure the transmissions are the same! The main reason i ask is because patricks makes a 3.55 gear for the 37! And if they are the same then i could use the gears for my truck.Yes i could change out to t5 and open drive but i want to keep it stock! Any help will be great
1936 and 1937 housings are different.
And, the carrier assemblies are different.
That does not mean the ring/pinion are the different (search that manual at the link-s above) - there are labeled diagrams. Or, call Patrick and ask him (or did you ask him already?).
___________
36 and 37 R&P look to be different?
I did talk to patricks and they said they dd not know too much about the 36
