5 members (Otto Skorzeny, KEVINSKI, Hanks custodian, SmalltownTRKGuy, 1 invisible), 69 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
Does anyone know who makes power steering pump brackets for the '66 292?
I really want to add it to my new one so my wife can drive it.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I believe the only brackets available are from the local dismantler. Not all the brackets will fit without some modifying if you have headers. I have a set from a 68 C50 that would clear headers. Also you want all the pulleys. Some have even made their own. If you want pictures I can post some.
Larry
I don't own a vehicle that isn't old enough to drink.
Hey John. You have a PM regarding the body badges, as well as, factory-correct power steering pump mounting brackets for a '64-'66 Chevy 292 six cylinder.
Does anyone know if the 250ci brackets are the same? Also, is it true that the integral head brackets are completely different? I also have a 292, and would like to put power steering on it. I would love to hear from anyone who has been through this, and has tips etc. on how to modify brackets if needed. Thanks!
I've got the 250 brackets for both non and integral head. The 292 block is almost 2 inches taller than the 250. If the 250 brackets have the alternator adjustment slot it will be off. The bolts for mounting PS b rackets on an integral head are a different location.
Larry
