9 members (Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, Tronman, TUTS 59, 2 invisible), 104 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#73759 02/23/2007 4:10 AM
Junior Member
Junior Member
I have a military 302 with holley two barrel,does anybody know what carb came stock on the civilian 302? I would like to know if a 270 or 248 water pump woud work on the 302?
Thanks Wayne
#73760 02/23/2007 4:55 AM
3B Offline
Hy masseyharris, my 59 has a stromberg on it, i'm not sure about impeller differences, but I do believe the waterpumps interchange, hope that helps.
#73761 02/23/2007 7:16 AM
Most civilian 302's came with a 2bbl Holley AA-1, which is a variation of the Holley 94 which came on Flathead fords. The AA1 has bigger venturi.
The bolt pattern on the civilian 302 is 3-bolt, I think most military ones are the 4-bolt.
Paint & Body Shop moderator
#73762 02/23/2007 8:05 AM
Wayne,
It doesn't really matter which carb was original for the 302, unless you are going for complete originality. Tell us a little about your project as you already have many of us salavating over that 302! cool grin
The 302s are great engines and can be ran with a variety of different fuel setups. The Military version had a super low compression ratio... 6.5:1 so it could run on 67 octane gasoline. The Low compression ratio Military blocks almost begs for a blower, giving you 200+ hp. With other modifications it is not uncommon to see these 302s running with a 4bbl or even multicarburation with 2- 5 2bbl carbs, or fuel injection.
#73763 02/23/2007 8:22 AM
You Know... I forgot to welcome you to the site. I just went back and read your first post... 2 1953 Canadian Jimmies that you are trying to make 1 out of. Pretty cool. Keep us up on your progress.
#73764 02/25/2007 1:45 AM
Junior Member
Junior Member
I have two 1953 canadian gmc which have the chev 216 engine.One truck runs but is rusty the other truck has good sheet metal.I was just given a complete american gmc chassis with a 248 and a three speed.The 248 is a standard bore,but needs a rebore,and a crank grind.I have not pulled the 302 apart yet,but I am leaning towards the 302,I am old school I believe big is better.I was considering a small four barrel carb,and using the 248 distributor with vacuum advance.
I am an engine machinist for detroit diesel canada,although I apprenticed as an auto mechanic.
thats about it
I restore and pull antique masseyharris tractors
thanks Wayne
