7 members (JW51, Uncles51, Jaison, Wayne67vert, Johnny Rib, Robert Crandall, 1 invisible),
70
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73759 02/23/2007 4:10 AM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | I have a military 302 with holley two barrel,does anybody know what carb came stock on the civilian 302? I would like to know if a 270 or 248 water pump woud work on the 302? Thanks Wayne | | |
#73760 02/23/2007 4:55 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy masseyharris, my 59 has a stromberg on it, i'm not sure about impeller differences, but I do believe the waterpumps interchange, hope that helps. | | |
#73761 02/23/2007 7:16 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Most civilian 302's came with a 2bbl Holley AA-1, which is a variation of the Holley 94 which came on Flathead fords. The AA1 has bigger venturi.
The bolt pattern on the civilian 302 is 3-bolt, I think most military ones are the 4-bolt.
#73762 02/23/2007 8:05 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Wayne, It doesn't really matter which carb was original for the 302, unless you are going for complete originality. Tell us a little about your project as you already have many of us salavating over that 302! The 302s are great engines and can be ran with a variety of different fuel setups. The Military version had a super low compression ratio... 6.5:1 so it could run on 67 octane gasoline. The Low compression ratio Military blocks almost begs for a blower, giving you 200+ hp. With other modifications it is not uncommon to see these 302s running with a 4bbl or even multicarburation with 2- 5 2bbl carbs, or fuel injection. | | |
#73763 02/23/2007 8:22 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | You Know... I forgot to welcome you to the site. I just went back and read your first post... 2 1953 Canadian Jimmies that you are trying to make 1 out of. Pretty cool. Keep us up on your progress. | | |
#73764 02/25/2007 1:45 AM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | I have two 1953 canadian gmc which have the chev 216 engine.One truck runs but is rusty the other truck has good sheet metal.I was just given a complete american gmc chassis with a 248 and a three speed.The 248 is a standard bore,but needs a rebore,and a crank grind.I have not pulled the 302 apart yet,but I am leaning towards the 302,I am old school I believe big is better.I was considering a small four barrel carb,and using the 248 distributor with vacuum advance. I am an engine machinist for detroit diesel canada,although I apprenticed as an auto mechanic. thats about it I restore and pull antique masseyharris tractors thanks Wayne | | |
