3 members (Otto Skorzeny, dt235sd, Rusted Nut), 80 guests, and 2 robots.
Topics128,048
Posts1,055,664
#736260 04/05/2011 12:40 AM
Truck started all winter in 0 degree temps and now suddenly won't start. Engine cranks. We checked the battery. Cleaned contact on rotor, tried again and got one spark, tried again no spark. I dressed and reset the point gap. Got spark. Then no spark. Any ideas? The truck is a 1950 Chevy 3600 216 if that's any help. Thank you.
Disconnect regular power and jump direct from battery. See if that corrects.
Do not leave jumper hooked up for too long. I would not leave on for more than minute or two.
6 or 12 volt? Do you have a ballast resistor?
If corrects then coil distributor and all that should be OK and you have a problem in wiring between coil and all. First place I would suspect is worn ignition switch. Check all connections for tight and clean and good crimps.
If you have VOM do a wire by wire resistance check. All readings should be 1 ohm or less except coil.
Dan Bentler
Do you have power on the coil when key is turned on? Get a light tester which is the easiest way to check to make sure you have power to the coil. Sounds like a supply problem to me. Make sure you have power from switch.
Steve in I-DA-HO
Leitmotif - Thank you for your response. What exactly do you mean by "Disconnect regular power and jump direct from battery"? It's a 6 volt system. Electric was never my thing. I'll give all this a try.
Bigdog58 - Thanks for your reply. We'll give that a try. We tried to bypass the ignition switch from the + battery terminal to the + coil terminal but we didn't have 10 gauge wire/would it have to be solid core as opposed to stranded, would that make a difference?
16 gauge wire should be plenty to carry ignition primary current, no need for the heavy stuff. Find a source of direct battery voltage like the big cable terminal at the starter, or the Battery terminal at the voltage regulator, and run a jumper wire from there to the coil terminal that DOES NOT connect to the distrtibutor. On a Chevy it will be the (+) terminal. With the jumper in place, the coil should produce a spark when the engine is cranked, regardless of the position of the ignition switch. Don't leave the jumper connected with the engine stopped and the points closed- - - -it will burn the points in a short time.
Thanks for yor input, took your advice and used the test light.The light lit when the ignition switch was turned to the on position.Where do I go from here?
