3 members (cmayna, BC59, Wickedbass), 51 guests, and 5 robots.
Topics128,086
Posts1,056,101
Members48,434
#734045 03/28/2011 8:03 PM
I have a single barrel Rochester B carb on a 1955 Chevy 235. Does anyone know what a Fel-Pro gasket number is for the carb to insulator plate? My local auto parts store has ordered 3 sets of gaskets and they are all wrong, either the bolt holes don't match or it covers the needle valve adjustment hole.
Riding in the Passing Lane
I don't have part numbers but that should be simple. They used the same gasket from 54 up well into the 80,s. There are various thicknesses. If it doesn't have a pathway from the power valve hole to the manifold vacuum you can cut a little hunk out of it.
1972 Chevy c10 Cheyenne Super
Check your mounting bolt distance.
Should be 2 15/16" center to center for a 235.
Sometimes a 216 intake/exhaust was used on a 235.
216 bolt center is 2 11/16"
-Tom
1950 Chevy 3100 w/ 1956 235
The narrower mounting bolt distance would most likely be FEL-PRO Part # 9520.
I bought a Fel-pro 8987 gasket and the vacuum hole on the carb base does not line up. The mounting holes are 2 15/16" apart.
Does anyone have any other ideas other than just cutting a hole in the wrong gasket? I know there must be a correct gasket out there somewhere.
Did you try... Felpro 9519
-Tom
