| | | Forums66 Topics128,052 Posts1,055,721 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Just wondering if you guys ever heard of actually mixing clear with single stage?
This is how my truck has been painted. Two coats single stage and then the last two are mixed 50/50 with clear. Seems to work great as the paint looks deep and shiny.
Just wondering how common this method is. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | pretty common around here, in fact I sell a urethane which requires clear mixed into the final coat. | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | My local PPG dealer told me to use 50/50 mix clear w/single stage for final 2 coats for a real deep shine. | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | The paint guy at a local O'Reilly's told me that the recipes for their acrylic enamels call for a certain amount of clear to be mixed in. I don't know how much but it soulds like putting more into the final coat should work.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Good to know! The paint looks really great. Do you think the extra clear helps protect against UV rays from the sun? | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | I was told it makes the finish more durable & much deeper shine, but not sure about fade resistance. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | One thing to keep in mind guys is the more coats of paint you put on, the more likely you are to get checking. While adding clear to your paint may be common don't get the idea that it's OK to pile the coats on to get that deep looking finish. Read and abide by the manufacturer's recommendations.
