1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 20 New Guy | | New Guy Joined: Feb 2011 Posts: 20 | Hi guys, my 48 half ton is missing the spare tire mount under the bed. Will a mount off of a '41 chevy truck work? Thanks, Keenan
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Jim Carter carries almost the whole setup. I have no doubt that a 41-46 mount could work on an AD truck. Whether it is a total correct VCCA restoration quality swap, I couldn't tell you. The carrier should be the same. The ramp should be similar, and the bolt, they are the same as well. | | |
