2 members (Barry Martak, lumbersawyer), 139 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#724833 02/27/2011 2:53 AM
che
Offline
hi guys. i hooked up a voltage reducer between the ignition and my heater on my 50 chevy. the volt reading before the reducer and after the reducer is just below 12 volts. shouldn't it read 6 volts after the reducer. i couldn't find an answer searching the forum although i'm sure it's there somewhere. thanks.
Che
1950 Chevy 3100
che #724853 02/27/2011 3:54 AM
If you are using a two terminal device, it will read 12 volts on both sides when the heater motor is not running. It needs a load before dropping the voltage.
1951 1 Ton Completed
Thanks truckernix, I was working on the same thing today and wondering about that. Man, this is a great information source!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
che #737031 04/07/2011 1:20 PM
The voltage drop across the reducer will change according to current flow. It's just a high-wattage wire-wound resistor in most cases. For instance, if a circuit that draws 10 amps gets reduced to 6 volts applied to a heater motor, etc., you would need a 0.6 ohm resistor with a 60-Watt minimum capacity. The resistor would consume 6 volts, and allow the other 6 volts to be applied to the heater motor. If the amperage changes, the resistance has to vary accordingly. Once the charging system kicks in and the available voltage goes up to 14.5 or so, all the calculations change. I like to use big wire-wound resistors with a sliding center tap so I can fine-tune the voltage for actual operating conditions, not some "one size fits all" voltage reducer.
