7 members (UtahYork, MickeyP, Gdads51, Cletus1950, TexasJim50, Hotrod Lincoln, baldeagle), 105 guests, and 2 robots.
Topics128,179
Posts1,057,068
Members48,460
i cant afford a quality paint job for a old short bed utility gmc and i was wondering.
how good is tractor and implement paint they sell at tractor supply company. i was also asking about there oil based primer they sell under the valspar name.
i already have the enamel hardener on hand i was also wondering how this would look using a paint roller because i have heard of people using a technique so it goes on smooth.
i have already sanded the truck and fixed the rust with patch panels and fiberglass body filler.
The problem with tractor paint, or straight enamel is that it will fade or oxidize.
I've used it on stuff but now have decided if I'm going to spend all that time on prep and want the shine to last I'm going to paint it with acrylic enamel.
Now I've got an old gas pump I restored and painted with Rustoleum 15 years ago. It's always outside and the paint has held up but looks pretty dull.
I used to wax it and bring back a shine, which I still could do if I had the time.
If you don't intend on letting it sit out, then the fade issue is not much to worry about, although straight enamels still don't have the gloss that acrylics will give.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
