1 members (JW51),
96
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | Truck started all winter in 0 degree temps and now suddenly won't start. Engine cranks. We checked the battery. Cleaned contact on rotor, tried again and got one spark, tried again no spark. I dressed and reset the point gap. Got spark. Then no spark. Any ideas? The truck is a 1950 Chevy 3600 216 if that's any help. Thank you. | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Disconnect regular power and jump direct from battery. See if that corrects.
Do not leave jumper hooked up for too long. I would not leave on for more than minute or two.
6 or 12 volt? Do you have a ballast resistor?
If corrects then coil distributor and all that should be OK and you have a problem in wiring between coil and all. First place I would suspect is worn ignition switch. Check all connections for tight and clean and good crimps.
If you have VOM do a wire by wire resistance check. All readings should be 1 ohm or less except coil.
Dan Bentler | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Do you have power on the coil when key is turned on? Get a light tester which is the easiest way to check to make sure you have power to the coil. Sounds like a supply problem to me. Make sure you have power from switch.
Steve in I-DA-HO | | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | Leitmotif - Thank you for your response. What exactly do you mean by "Disconnect regular power and jump direct from battery"? It's a 6 volt system. Electric was never my thing. I'll give all this a try.
Bigdog58 - Thanks for your reply. We'll give that a try. We tried to bypass the ignition switch from the + battery terminal to the + coil terminal but we didn't have 10 gauge wire/would it have to be solid core as opposed to stranded, would that make a difference?
| | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | 16 gauge wire should be plenty to carry ignition primary current, no need for the heavy stuff. Find a source of direct battery voltage like the big cable terminal at the starter, or the Battery terminal at the voltage regulator, and run a jumper wire from there to the coil terminal that DOES NOT connect to the distrtibutor. On a Chevy it will be the (+) terminal. With the jumper in place, the coil should produce a spark when the engine is cranked, regardless of the position of the ignition switch. Don't leave the jumper connected with the engine stopped and the points closed- - - -it will burn the points in a short time. Jerry
| | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | Thanks for yor input, took your advice and used the test light.The light lit when the ignition switch was turned to the on position.Where do I go from here? | | |
