2 members (55shaker, Steelonsteel), 117 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
I'm looking to buy a 1948 GMC, With no engine. But i do have a 216 & a 235. Would there be any problems with the install, being a GMC instaed of a Chevy. Do they bolt up the same, How abouth the tranny. any mods i would have to do. Thanks in advance
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
No, they won't line up the same. GMC engines are longer...different front mount. BTW, GMC's of that era are ND
(New Design) I'd try to find a Jimmy engine if it was me...
Steve
'49 3800
'52 3600
'57 3100
Lots of GMCs were repowered with Chev. The Chev is about 1 1/2" shorter. A plate on the front mount will fix that. The rear will require no changes. Many Chevs drop the exhaust out the rear while GMC drops it out the center. However, I agree that you should look for a GMC. Even a 228 will be far superior. A 248 or larger is even nicer.
My '53 GMC has a Chevy 216 in it. It had a 235 before that, and if I don't find a Jimmy motor before the swap, it will get another 235.
I would, however, prefer a Jimmy motor.
