2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | I'm looking to buy a 1948 GMC, With no engine. But i do have a 216 & a 235. Would there be any problems with the install, being a GMC instaed of a Chevy. Do they bolt up the same, How abouth the tranny. any mods i would have to do. Thanks in advance
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | No, they won't line up the same. GMC engines are longer...different front mount. BTW, GMC's of that era are ND (New Design) I'd try to find a Jimmy engine if it was me... | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Lots of GMCs were repowered with Chev. The Chev is about 1 1/2" shorter. A plate on the front mount will fix that. The rear will require no changes. Many Chevs drop the exhaust out the rear while GMC drops it out the center. However, I agree that you should look for a GMC. Even a 228 will be far superior. A 248 or larger is even nicer. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | My '53 GMC has a Chevy 216 in it. It had a 235 before that, and if I don't find a Jimmy motor before the swap, it will get another 235.
I would, however, prefer a Jimmy motor. | | |
