1 members (WingWright),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I have my 52 3600 cranking and running on first start now..... finally. Only problem is now Im noticing things. I have a valve knock coming from cylinder 3 it sounds like. Also around the spark plug a small puff of smoke will come now and again. I was told when the motor warms up a lot of the knocks go away. is this true? Also it sounds like I have a major exhaust leak at the manifold. All these combined, does this sound like I have a serious problem or is this expected with a truck that sat in a field for thirty years?
I know this is probably a dumb question but I am trying to get the truck running ok to leave for the wedding and I would rather not ruin the truck in the process but dont have time for a rebuild of the motor either. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the only way smoke could come out around a plug is if it's loose or there's a major crack there - or if a 216, maybe the side cover is loose and some oil is leaking there and burning off? .... for the "knock", it would be a good idea to have a mechanic listen to it, could be a problem or just need a valve adjust .... if the engine sat unused for 30 years I wouldn't have much faith in it - might want to arrange to have a tow truck in the wedding parade  Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it is a 216, it could be just blow-by coming out around the sparkplug. I guess another possibility is a cracked or loose plug. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you are hearing a "knock" that goes away as the engine warms you most likely have a bad connecting rod. If you're hearing the "tapping" of a lifter that goes away as the engine warms it's pretty much normal except that you should hear them all, not just one. If you're only hearing one it sounds like a valve lash setting session is in order.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tiny, bearing noise usually gets louder as the oil warms and thins out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I was thinking a valve lash adjustment was needed too.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I was thinking a valve lash adjustment was needed too. What engine do you have in your 52? Have you done any work on it? Have you timed it? A ticking sound I experienced on my 235 was a bent push rod. The "major exhause leak sound" you describe should be addressed. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Tiny, bearing noise usually gets louder as the oil warms and thins out. I have one slightly knocking on cold start and as the oil gets pumped up to fill in the space it goes away and stays away until the next cold start. One of these days I'll get my well fed self under the car, pull the pan & remove a shim or two to shut her up for a while.
| | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | DADS50 I believe I have made a mistake. I thought it was a 235 but I believe its a 216. I have not been working on the motor long. I have spent most of the time I have had the truck rewiring and handling smaller things that took less time. I was in between moves. All I have done is put new spark plugs, cap and rotor button, wires, ignition coil, rebuilt the carb. Things like that. I noticed today when I pulled the valve cover with the engine running that there was some huge gapping in the valves. Also I believe two rods were bent because they were not going straight up and down. They were dancing around a pretty good bit. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Sounds like you found at least one problem. Replacing the bent push rods and setting the lash sounds like a good plan. I got push rods for my 235 at my local O’Reilly’s auto. Napa can get them also. I used the valve setting instructions by Nathan Hall ...click...They were helpful for me. Good Luck | | |
