2 members (BC59, Uncles51),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Going to buy new tires for my 59 3100. What would you guys look for? Thanks Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | depends on what you use it for ... Yokohama 700R15LT work for me, haulin loads, but 10 ply are a bit harsh if all you do is cruise the main - whatever you get, make'em radials, as good as power steering  Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | X2 on radials. I'm partial to Michelin and BF Goodrich myself. 215/75/15 is pretty close to the 6.70-15 base tire size.
Bill Burmeister | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Well... I just bought 2 new 7.00-15 8-ply "D" bias Power King highway treads for the front of my 50 3600. I put 2 new Super Tractions on the back about 3 years ago. They probably have all of 750 miles on them, and run great. I knew that the rear tires were made in China so I expected that for these new front tires. Nope: Thailand! Right on the side of the tires. The new tubes? Made in Korea. After I saw that I didn't even look at the flaps to see where they were made... I know the Model T guys (complain) and moan all the time that all the tires available for their cars are made in Vietnam... But it's not just antique stuff; A guy at work recently bought a new set for his late model F-150 and they were Hankooks, made in Korea. Go figure.
Professional Novice
| | | | | Joined: Mar 2011 Posts: 65 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 65 | My 59 has 235/75/15 Goodyear Wranglers. I cant get enough of how good they look! pic 1 pic 2
1951 1/2 Ton 216ci 4spd 1955 3/4 Ton NAPCO 235ci 4spd 1959 1/2 Ton stepside 235ci 4spd
