0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73571 02/20/2007 2:32 AM | Joined: Mar 2005 Posts: 25 Apprentice | | Apprentice Joined: Mar 2005 Posts: 25 | I have a 1955-66 Chev PU (55T) 1/2 ton rear end...the drain plug is screwed up and I need a replacement. Can anyone tell me what size plug I need...5/8 " or 3/4 or what...
I believe a pipe plug will work will it not | | |
#73572 02/20/2007 3:22 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With the old one in hand, have you tried a hardware store? | | |
#73573 02/20/2007 4:43 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I do believe it is a 3/4" thread. Like Grigg said, take it with you, only I'd suggest going to the flaps. Should be able to match it up without too much trouble.
Bill Burmeister | | |
#73574 02/20/2007 10:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Are you refering to the fill plug on the back of the cover or the drain plug in the bottom of the housing. The drain plug is a standard pipe thread & available at any hardware store. You will want to get one with a recessed head so you wont hit it on something. The fill plug is a special plug available at the specialty suppliers or dealer. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73575 02/21/2007 3:27 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I hope you find what you need, but if you don't or the female threads are buggered up you might try this. I hate to drop a tranny pan that doesn't have a drain plug. When I do get it off, I fix the problem. I drill a hole in a lowest section of the pan 3/8". Then heliarc a 1/2-13 machine nut over the hole. Then screw a 1/2" screw with copper washer into the nut. No more splashing tranny oil all over. I know the oil pan is a much bigger issue but if it's got to be fixed....
#73576 02/21/2007 3:29 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Oops, missed the mark. Thought you were adressing an oil pan, sorry.
#73577 02/21/2007 5:59 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | At least with a rear end it's easy to pull the cover to repair the threads. I've found that they are usually pipe threads. You might be able to find one with a magnet in it at your local FLAPS.
