| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I have a rear view mirror mounted to each fender. Each base plate is held to the fender with 3 screws. What type of screw head is used? (I'm not inquiring about the thread form.)
Round head, pan head, button head, oval head?
Phillips or flat head?
Bright or painted black (like the mirrors?)
Bill | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the ones that are actually mounted on the doors, as shown in your gallery pics, or some aftermarket ones added on to the fenders? oval head phillips looks OK, but the originals are quite like the screws that hold the inner metal door panel, phillips heads that have a slight lip around the outside so the head is a bit 'countersunk'
Bill | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Right again, Bill. I wrote "fenders" when I meant "doors."
I know what you are talking about, with the door panel fasteners. I'll shoot for that look. Right now I have 2 round heads and 4 flat heads. I'll switch to oval head phillips.
One last question: should these be painted black like the mirror base, or left bright? Mine are bright, but look out of place. I'm leaning black.
Bill | | |
