0 members (),
84
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | Does anybody know a part number and/or, where to get king pins and bushings for a 1968 C50? Checked mine the other day and they're shot.  Thanks... | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy pipeliner78, 1968 C50 with 5000lb. front axle, Moog 8492B $43.89 at Rock Auto, hope that helps. | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | It does. Thanks for all of your help. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Pipeliner78, please disassemble one side and give us pin diameter measurements and length, just in case your truck has a heavier front axle in it. The pins for the 5000 lb. axle are 1.109" diameter X 6.343" long, hope that helps. | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | I will first chance I get gone to working 7-12's not much time for tinkering. | | |
