0 members (),
389
8
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 10 New Guy | | New Guy Joined: Feb 2011 Posts: 10 | I am restoring a 1949 Chevy 6400 firetruck. The rear end is frozen. I'm hoping its the brakes. I took the wheels off and pulled the pumpkin cap to find a splined hub. How do i remove the brake drum after backing off the adjuster? Do I need to pull the axle? Thanks, Stan | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Those drums can get rusted on. Once the brakes are backed off - remember, there is an adjuster for each shoe - use some curse words and some persuasion. | | | | | Joined: Feb 2011 Posts: 10 New Guy | | New Guy Joined: Feb 2011 Posts: 10 | Hammer, pipe or C4 persuation? I know there are two adjusters but which is which or does it matter? The manual leaves a few tidbits out. Stan
| | | | | Joined: Apr 2006 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 48 | If the brakes are frozen, you wont be able to move the wheel at all. One wheel may be frozen, or both could be frozen. If a wheel spins a few degress and then locks up, you probably have some rear end problems. You might try backing off the brakes and rock the truck with a tow chain attached to another truck. The jarring would probably brake the drums loose. I have also heated the drums with a torch and hit them with a sledge hammer a few times. I try not to do that method if possible. I'm always afraid that I am warping the drum by beating on them. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | You will need to remove the axles first unless they have three screws around the drum at the stud line, if those can be removed then you can try to get the drom off, if they are stuck ytou may want to just pull the axle and the the complete hub now you can also check bearings and replace the seal. You'll need to back off both adjusters on each side to loosen the brake shoes. | | | | | Joined: Jun 2009 Posts: 98 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 98 | Ive had some sucess unbolting or loosening the wheel cylinders while pulling off drums. Helps stuff move around inside the drums.
| | | | | Joined: Feb 2011 Posts: 10 New Guy | | New Guy Joined: Feb 2011 Posts: 10 | Thanks to all who answered my question. Today I backed off the brake adjusters and hit the side of the drums a few times. After a beating they broke loose. Now on to the paint shop.  | | |
