5 members (klhansen, 69Cuda, FAST55, dt235sd, 2-Ton), 87 guests, and 5 robots.
Topics128,050
Posts1,055,667
#73490 02/18/2007 1:52 PM
Has any of you guys ever used a tillotson carb. I've found a nos Tillotson that says it is for a 41-52 chevy just wondering if they were any good.
Thanks Tony
#73491 02/19/2007 1:54 PM
Carburetion specialist
Tony, if it is the one with the cast iron base; we remove the bases from 2 of them, cut them in half and reweld them to form adapters. The rest of the carb goes into the "round" file.
Jon.
The Carburetor Shop
#73492 02/21/2007 1:37 AM
Thanks carb king I'll see what I come up with, I'm always ready for a challenge. How are the bases cut.
#73493 02/21/2007 1:42 PM
Tony - we cut the bases right below the throttle shaft, and then weld two cut bases together to form a "cross-flange" adapter. The cross-flange adapter is useful for adapting a Zenith or Stromberg with the base turned 90 degrees to something else.
Jon.
The Carburetor Shop
