2 members (Rusty Rod, porsche), 64 guests, and 3 robots.
Topics128,021
Posts1,055,357
Members48,420
V
V Offline
I am working on the daughters truck and fabricating a cross-member to support the TH350 I stuck on the 235. My question is : Is it a NO NO to drill the flanges of the frame? I know it is not recommended on modern hardened frames, but I was wondering if it was taboo on these as well. And while I'm asking I just want to confirm drilling the web is OK on the frame.
Thanks in advance for your time. I couldn't do it with out without all the knowledgeable support here.
http://www.facebook.com/home.php?sk=lf#!/pages/Jessicas-59-Apache-Page/130140737020875?sk=photos
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
never found it a problem, just make sure you use grade 8 bolts
V
V Offline
Thanks for the reply.
Jessica's Truck
In my book its a no no to drill, weld or modify a nice stock frame on any task force truck. If a person has to do that they should find one that someone has already messed up and use that.
Why? Because we don't even have the luxury of a chinese built frame, when all the good ones are gone.
V
V Offline
Thankyou for your opinion.
Jessica's Truck
