7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible), 123 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
#733967 03/28/2011 4:38 PM
Need to remove the rear cab window from a parts truck and install it in my driver truck. Looking for advice. Thanks.
danman #733999 03/28/2011 5:53 PM
Use new, warm rubber!
Cut old rubber all around with razor knife & pop glass out.
Dish soap is good installation lube. Put new rubber on glass, & small cord in outer groove with cord ends hanging out together at bottom. Set in place on lower edge of cab opening, with as much of the "flange" in the groove as possible, and ends of string inside cab. Working slowly, pull cord out, which will spread open the rubber groove, and push glass/rubber onto flange as you go. Obviously, this is much easier with an extra pair of hands. Hopefully, it's all in place when you get around to the other end of the string!
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Thanks Starfire. I'm gonna order the new rubber.
danman #734291 03/29/2011 1:22 PM
I'm getting ready to do the front glass, and am a bit confused by "small cord in outer groove with cord ends hanging out together at bottom" can yu explain a bit more?
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Modelman #734315 03/29/2011 2:09 PM
Jake, Here's My Classic Car video with Steele Rubber replacing a windsheild on a '67 Chevy. Technique applies to your truck.
Drew
Modelman #734386 03/29/2011 5:33 PM
I bought a 50' spool of 3/16" smooth nylon cord. It's just handy to have, and works well for this kind of thing.
The rubber gasket has two grooves: one each on the inside and outside. The inside groove fits on the outside edge of the glass. The outside groove fits the "pinchweld" flange around the window opening.
Install the rubber on the glass. Starting in the middle of the bottom, push the cord into the outside groove all around, leaving about 6" "tag" ends of the cord hanging out together...these are to get ahold of.
Set window in place with cord ends inside, and engage flange in groove as much as possible. Pulling the cord will spread the rubber groove over the flange. Work both ways on big windows, pushing and nudging as you go, until the last bit of cord pops out and the window is in.
For the guys at the glass shop, it takes about 3 minutes. It took me and a helper about 15 minutes, and we had to start over once.
Good luck.
cm
1965 Chevy C10
