| | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | does anyone know what the part numbers are for a 1950 6100 : clutch disc / pressure plate / throw-out bearing?
want to order before I pull everything out.
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Any part numbers you get for the pressure plate and disc wold be a guess, better pull it out and see what you have for sure. No telling what clutch someone put in it over the years.
Ideally you would have an 11" clutch, (might actually measure 10.75") The pressure plate for that size clutch is held on with 9 bolts. Clutch disc should have 1.125" 10 splines if I remember correctly.
Again, best bet is to pull your old stuff out and likely have them rebuilt, or at lest know for sure what you need to find.
Grigg | | |
