0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I have a single barrel Rochester B carb on a 1955 Chevy 235. Does anyone know what a Fel-Pro gasket number is for the carb to insulator plate? My local auto parts store has ordered 3 sets of gaskets and they are all wrong, either the bolt holes don't match or it covers the needle valve adjustment hole. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't have part numbers but that should be simple. They used the same gasket from 54 up well into the 80,s. There are various thicknesses. If it doesn't have a pathway from the power valve hole to the manifold vacuum you can cut a little hunk out of it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Check your mounting bolt distance. Should be 2 15/16" center to center for a 235.
Sometimes a 216 intake/exhaust was used on a 235. 216 bolt center is 2 11/16"
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The narrower mounting bolt distance would most likely be FEL-PRO Part # 9520.
| | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I bought a Fel-pro 8987 gasket and the vacuum hole on the carb base does not line up. The mounting holes are 2 15/16" apart.
Does anyone have any other ideas other than just cutting a hole in the wrong gasket? I know there must be a correct gasket out there somewhere.
Thanks | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Did you try... Felpro 9519
-Tom
