1 members (Samantha),
45
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | I am working on the daughters truck and fabricating a cross-member to support the TH350 I stuck on the 235. My question is : Is it a NO NO to drill the flanges of the frame? I know it is not recommended on modern hardened frames, but I was wondering if it was taboo on these as well. And while I'm asking I just want to confirm drilling the web is OK on the frame. Thanks in advance for your time. I couldn't do it with out without all the knowledgeable support here.
http://www.facebook.com/home.php?sk=lf#!/pages/Jessicas-59-Apache-Page/130140737020875?sk=photos Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | never found it a problem, just make sure you use grade 8 bolts
Bill | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | In my book its a no no to drill, weld or modify a nice stock frame on any task force truck. If a person has to do that they should find one that someone has already messed up and use that. Why? Because we don't even have the luxury of a chinese built frame, when all the good ones are gone.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Thankyou for your opinion. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | |
