0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 50 | This question is just for my information-doesn't actually apply to my truck. Back in the old days, my dad had a 55 second edition long bed. The truck has a 235 engine and a 4 speed hydramatic. At the time I was a teenager who thought he knew everything, but in reality knew almost nothing. I thought the transmission was really good. Were these transmissions rare and when did they stop making them? Lee Beckman | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lee, They were relatively rare compared to manual transmissions (maybe someone has Chevrolet truck hydra-matic production numbers but I doubt it). GM supposedly stopped making the 4-speed Hydra-Matic transmissions sometime around 1964. http://en.wikipedia.org/wiki/Hydramatic | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As far as trucks go, what Tim said is true but Hydra-matics were quite common in cars. Not just in GM cars either. They were also used in Lincolns, Packards and others. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most of the "others" are listed at the wikipedia link:
1951-1953 Hudson 1950-1953 Nash 1951 Frazer 1951-1955 Kaiser 1954-1955 Willys 1949-1954 Lincoln In 1952, Rolls-Royce acquired a license to produce the HydraMatic under license for Rolls-Royce and Bentley automobiles. It continued production through 1967.
First used in Oldsmobile in 1939 (then Cadillac in 1941). Saw service in WWII.
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | this sounds very much like the transmission that is in the 55 2nd serie,s i just bought its coupled to a 347 v8,
live or die do it with spanner in hand
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I had a '52, a couple of 53's and a '57 olds with Hydramatics and they were a good solid hard shifting transmission. Beefing up the valve body with stiffer springs and or shims allowed higher rpm between shifts and even when stock you could manually shift them almost like a stick. I would think that they were the same trans used in the mid-50's trucks. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | i,m shure thats what it is but the shifters missing so i,v got to find something suitable or make something
i,m led to believe the position lay out is unesual /odd as regards the reverse position and that it does,nt have a park position that you place it in reverse with the motor switched off to park????
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | The early HydraMatics used a parking pawl on the output shaft that engaged when the shifter was moved to reverse with the engine off. Beginning in 1956, the Controlled Coupling Hydramatic shift quadrant included a Park position, but that transmission was never used in trucks. Jerry
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | i,m ,,still,, learning,, lol
i think the tranny may have come from a car the info i have on it is CA-56 number 5899 made in 1956
i dont know if anyone can tell me more about it
i,d appreiciate any thing anyone can share
