2 members (PAUL Berardi, 78buckshot), 175 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#732817 03/24/2011 1:27 PM
Will a 1953 3100 1/2 ton center section swap into my 1938 chevy half ton rear end housing? I found a third member and torque tube assembly on line and was wondering about swapping it for mine, due to the broke off propeller shaft.
1938 Chevy pickup (old farm truck) that I received from my Great-Grandma. Ran when parked inside in '76.
3B Offline
Hy fireplug603, welcome, well the gasket is the same for at least 1938 through 1955A series, there may be wheelbase differences to deal with, I never checked more than the gasket, hope that helps.
3B #733166 03/25/2011 6:02 PM
38-39 was the last of the spiral cut gears. Starting in 40 they went to conventional gears (can't remember what they are called, hypoid?) The gasket pattern is indeed the same but there are differences. 38-39 had the ring gear rivited to the carrier. After that, they were bolted on. This shifted everything by 1/2". The change is reflected in the axles. 38-39 axles are the same length. After that, the axles were of different length. They also used different splines on the axles. In addition, axle housing shifts everything by 1/2" to compensate.
You could use the complete differential and housing from a 40 plus, except, the propeller shaft, torgue tube will probably be a different length. Check the parts book and you will see the the propeller shaft came in a bunch of different lengths. You may get luckey and find one the same length (possibly 40) but probably not.
Donf #733461 03/26/2011 11:58 PM
Thanks for the info. I will be measuring everything for sure.
This is such a great site.
