2 members (Otto Skorzeny, Nick in Manitou), 113 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#73249 02/19/2007 11:45 PM
I did another dumb thing and did not pay close enough attention when removing the 3 speed shift control unit that is mounted just above the steering box on the steering column. (58 Chevy, 3 speed, manual steering) :mad:
I first disconnected the shift lever and upper rod coming into the cab. On the lower rod that goes into the shift control box, there was a coil spring and 2 pieces of a rubber boot.
1. What is the purpose of this spring and rubber boot?
2. Where do they go?
I have looked in both the Service manual and Factory assembly manual and can't find anything helpful, so now I am turing to the most trusted and knowledgabe source of information.
H E L P!
Bob
Bob, the spring goes inside the box between the 2 pawls to keep them tensioned apart so they "click" into the slots, the boot goes on the shaft aagainst the outside box to keep dirt out
