1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 23 New Guy | | New Guy Joined: Jan 2011 Posts: 23 | I know the hood is wrong and it needs work but is the price ok? I'm just looking for a decent little project just needing to know. http://bgky.craigslist.org/cto/2238434274.html- Jake | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | Depends on what you want to do with it. You won't find a running truck for much less than that. Check all of the major componenets (ie) clutch, trans., does it run OK? Does it smoke excessively? If everything seems preety good, then I would say go for it! If you want to make it "new" again, be prepared to spend lots of $$$$$$ Otherwise, it will be a lot of fun. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I agree with Kerry, check it out good, but with the amount of rust that is showing, it will have a lot more rust on the underside. Unless you love to do rust repair, I would look for a more solid truck, even if it would cost you a little more money.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | That is not a little project, it's a big project. Also, take a look at the roof lip above the windshield. That is also a big problem if it is rusted badly. If you are good at body work and can do your own painting etc., and are willing to invest $$$$, I say go for it. The price is right and there aren't that many '62's around. | | | | | Joined: Jan 2011 Posts: 23 New Guy | | New Guy Joined: Jan 2011 Posts: 23 | yeah i see what yall are saying i went and checked it out. The only big items is what are on the doors rockers and cab corners everywhere else is solid even the top of the cab.
but what is with the hood and what model does it belong to because i know it isn't no viking C10. | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | I believe it is off a 1960 if it is decent some guys really like them you should not have trouble trading or selling it if it is nice. Kieth
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | It's a 61 "eyebrow" hood but the same as a 60 just different inserts, a lot of them were traded off for the newer hoods because of rust along the bottom edge especially at the corners next to the fenders on the back. If its pretty clean you'll have no problem trading it off at all.
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | I agree with the advice offered above, and will add - unless you are looking for a simple little project like having an old truck to haul things to the dumps, I’d say look for something better. Rust is like and iceberg, and if you can easily see what shows, there is probably a lot more. At least confirm for sure before bringing it home. It’s likely the floor and the cab mounts are also rusted out. Rust repair is a tedious and thankless task, and requires either a lot of money, or a lot of free time, welding skills and a passion for being dirty.
On the plus side, those 60-61 hoods can go for over $500 if they are rust and dent free. They were often replaced by owners that preferred the 62-66 version, and once spare parts inventory was exhausted they were superseded by the later design making them rare (in good condition) today. If however it's as rusty as the door and rocker, it will not have any significant value.
