1 members (2-Ton),
68
Mod | | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 4 New Guy | | New Guy Joined: Mar 2011 Posts: 4 | just bought a big bolt and doing the one over found driver side front bearing burned where could i find a set for under 100 dollars ??? | | | | | Joined: Oct 2010 Posts: 8 New Guy | | New Guy Joined: Oct 2010 Posts: 8 | I don't know about the $100. But, on my l946 two ton, I took out the original Hyatt bearings and then went on the internet and found a cross reference page to Timken bearing numbers. The local Adance Auto store was able to get me the comparable Timkens. I had to replace both inners and outers because the Timkens were not of the same "barrel" Hyatt design. This is a real challenge. Good luck. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | | | | | | Joined: Aug 2001 Posts: 3,619 Moderator | | Moderator Joined: Aug 2001 Posts: 3,619 | Welcome to the Big bolt group. NAPA had them for me about seven years ago. They had to pull the old books out from under the counter to find them.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I wouldn't count on NAPA having them. I spent 2 hours with a very patient NAPA dealer in WA. They are very hard to find and he came through with the seals but not the bearings. I got my bearings from Chevs of the 40s, but it took a long time to get them in. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2011 Posts: 4 New Guy | | New Guy Joined: Mar 2011 Posts: 4 | I Found Oriellys auto has them on order my question is can they be found for less than 160 a side inner and outer | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Used ones can be had cheaper... I have some 2 ton hubs, spindles, and brake parts listed in the parts for sale section.
Grigg | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | I am assuming you are talking about the bearing with the shoulder on it for the seal to ride on. I found some on eBay a few years ago by Hyatt number. Other than that, you won't find any new ones cheap. Good used ones with today's grease will last a lifetime. In my opinion, that's the way to go. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | You know it baffles me that they aren't available. You would think that there are enough of this rigs around to have enough demand. This comes up quite often. I guess to set up a run of bearings, they just have to make too many to make it profitable.
I have a 1955 Oliver tractor with pinion thrust bearings that are obsolete. I found two sets of used ones. One set I installed and I am putting the others on the shelf just in case. But that bearing was used up to the late 60s on other tractors at least. You would think that isn't THAT old not to be available under any brand. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | In the shop I worked in a couple years ago they were repairing one of the lathes, a 16x30 Lodge & Shipley from the late 50's early 60's, same as the one I have at home now.. The Timken spindle bearings were made to order for several thousand $ and the lathe was out of commission for 4-6 months waiting for them..
I expect if you want a bearing bad enough you can have it made.
Grigg | | | | | Joined: Mar 2011 Posts: 4 New Guy | | New Guy Joined: Mar 2011 Posts: 4 | thanks for the help oriellys had them but it was over 300 dollars for the inners and outers the price you pay for safety in a old truck i will be soon posting some pics to the gallery soon
Brek Webber | | |
