11 members (Rusty Rod, klhansen, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 3800GUY, Oswald, Wally / Montana, 1 invisible),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | Does anybody know how I can find out what rear end I have under my 68 C50. I can't find a tag on it. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, could you tell us what the g.v.w. of the truck is, and is it a single speed or two speed rear axle? | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | The g.v.w. is 19,500, and it is a two speed rear end.
| | | | | Joined: Aug 2003 Posts: 65 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 65 |
51 Chevrolet Canopy Express 02 K25 Duramax Crew Cab
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, if it's an electric shift it's an Eaton model 16121 or 16221, if it's a vacuum shift unit I'll have to do more looking, hope that helps. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If it's a vacuum shift it will more than likely be a Corporate GM rear rated at 15.000 pounds. Mike B  | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | It is a vacuum shift. I'm needing brake parts for it and the guy at napa said if i knew what kind it was he could look up parts for it. Or if any body knows part numbers for the brake parts. I need every thing. Years ago the cylinders froze up and we cut the adjusters, and took everything out. Of course it has been mis placed. Any help is appreciated. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, if you know the diameter and width of your brake shoes your parts man should be able to figure out what you need. | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | Ok I think they're 14 X 6 would that be right? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, all the rear brake diameters in my brake book are 15", there are two different widths mentioned 4" and 6". The wheel cylinders listed for the six inch wide shoes are a 1 5/8" bore. Do you have anything left to compare to? | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | I did find two of the brake shoes but i'm not sure how to measure them. | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | i just went and measured the width is 5 inches. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Pipeliner78, Unfotunately the middle to late 60s are a time of change for truck braking systems. Is your master cylinder a single or dual system type? The rear brake shoes appear to be the same from 1966 - 1970 on the 15000 - 28000lb. two speed axles o.e.m. p/n 3912439. Your rear brake system could be General Motors automatic adjusting type, Wagner manual adjusting type, or Wagner automatic adjusting type, I'll try and narrow it down a bit more. Any chance of posting a picture of what you have left? | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | It is a single master cylinder. It has two wheel cylinders for each side. and it has automatic adjusters, kind of like on a smaller truck. I haven't pulled anything off yet, so i don't have a picture. Thanks alot for all your help so far!!!  | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | Sorry I'm not more help describing my own truck.  | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | It also has an arm attached to each shoe like on a smaller truck. The one that touches the adjuster. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, I've done some more research, and I think what you have is the General Motors rear brake setup. Parts I have found are upper rear wheel cylinder o.e.m. 5464135, Raybestos p/n WC37159, $29.79 at Rock Auto lower rear wheel cylinder o.e.m. 5464136, Raybestos p/n WC37160. $29.79 at Rock Auto rear brake shoes Raybestos p/n 442PG $204.89 at Rock Auto, hope that helps, if you need more parts, just list what you need. | | | | | Joined: Oct 2010 Posts: 17 New Guy | | New Guy Joined: Oct 2010 Posts: 17 | Well getting ready to swap 7:17 ring & pin gear and hopeing all goes smooth any Eye Opening suggestions. worried about getting pin bolt off heard it was torque 300 pounds I just want to pull it and change the pin gear get the bearing taken off and pressed on new pin gear then change the ring gear..... hope all goes smooth | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | Thanks alot 3B. One more question. Do you have the number for the wheel seal? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, I beleve the o.e.m. pn for the inner hub seal is 3874368 that is equal to National 9128S, Rock Auto has one at $7.42, so the second one would be a different price, hope that helps. | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | Thanks alot, you've been a huge help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, you asked about adjusters in a PM, are you asking about the entire adjuster setup or just the adjuster screws? | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | I need the entire set up I've lost the parts we took after one of the cylinders froze up. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, okay these parts are all made by Euclid, and I couldn't price them because Rock Auto doesn't seem to carry Euclid return spring set [enough for the whole axle] p/n E-4023 replaces o.e.m.341520 hold down kit [enough for one wheel, may include return springs for one wheel] p/n E-4121 automatic adjuster kit RH [enough for one wheel] p/n E-4122 RH automatic adjuster kit LH [enough for one wheel} p/n E-4123 LH hope that helps. | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | Does it have 2 adjusters on each wheel or just one, the backing plate looks like it might be 2? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pipeliner78, according to my drawing, each shoe has its own adjuster, hope that helps. | | | | | Joined: Dec 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 48 | That's what I thought, thanks. | | |
