| | | Forums66 Topics128,055 Posts1,055,785 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | I purchased a new speaker for my 59 Apache. The new speaker is a little to deep for the old speaker box. I was thinking of cutting a larger hole behind the speaker box. Anybody think this may cause a problem? Did the OEM speaker require a hole cut behind the speaker box? Thanks Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, the original speaker stuck out of the cover and needed a hole in the header see page 3, but there's not a lot of room behind that inner panel Bill | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Thanks Bill for the info. Do you know what color the speaker housing was painted? Larry | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | same gray as the factory interior, although they might have changed by 59 with the gold-ish 59 interior, I've never seen an original in a 59
Bill | | |
