9 members (treegrower, Wayne67vert, 55shaker, Bill Hanlon, moparguy, Phak1, Oswald, 2 invisible), 65 guests, and 1 robot.
Topics128,089
Posts1,056,005
Members48,430
Hi guys, I'm looking to convert my delco 1112353 distributor to a pointless setup. Does anyone know of a kit.
thanks
1937 Chevy 1/2-Ton Pickup x3
1940 Chevy 1/2-Ton Pickup
1940 Chevy 1 1/2-Ton COE
1941 Chevy 1/2-Ton Pickup
1941 Chevy 1 1/2-Ton COE
1941 Chevy 1/2-Ton Suburban
1946 Chevy 1 1/2-Ton COE
1971 Chevy 1/2-Ton Pickup
I ran a pertronix on a delco with that same Serial Number(On a 1950). Its a 1167 ignitor.
Here is a pic ...click...
If you do decide to go with pertronix I suggest calling them.
Give them your delco s/n, voltage, and have them tell you the correct set up.
There is more than one product for GM 6 cylinder.
Here is another suggestion.
Before you remove the distributor put your timing needle on the ball. Note where your rotor is pointing i.e. #1 or #6.
Then after you convert your distributor you will know exactly where your rotor should point when you drop it in.
I used the flamethrower condenser they offer. Its internally regulated.
Install new plug wires, cap , and rotor ,spark plugs at the same time. Increase your spark plug gap per the instructions
Then re-time.
Good Luck
