| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | I need you guys opinion about motor mounts for my 59 3800 truck, i can't find a good quality v-8 after market motor mount to mount my 283 and turbo 350 tranny into my stock frame, Some of my rat rod buddys keep telling me that all i need is to use the stock front mount motor mounts and a after market tranny mount, Others buddys tell me that it would be too much stress on the tranny to engine bolts because the mounts are too far apart. I thought this too but now i'm not so sure if that isn't to bad of an idea, i need help with this, the right opinion could save me money or cost me a bunch | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Does the engine you're using have provisions for the side mounts? That might be one option. Another might be to use the factory mount up front, then use a motor plate between the engine and trans to use the original rear motor mounts. You'll probably have to fabricate it if you go that route.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you need 3 point mounting. there are after market crossmembers that you can put in for eng side mounts. I bought back in 63 a setup that would put a sbc in my old 32 chev sedan basically the same frame as your truck ron | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | the 283 that im using is the stock motor that came with the truck, it has the mount in the block to use side mounted motor mounts just like 70-80's 350 chevy motors the truck came with a 4-speed bulldog and the bellhousing cross member that mounted it to the frame, I have removed that crossmember so that i could mount the th350 and have room for things like power brake master/booster. I don't know how much hp a 283 with edlebrock intake and 4barrel carb will make but i know im not going to drag race it! I also know that 1-ton trucks should have 4speed trannys, but auto's just make driving then so much easier | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | do NOT try to run an automatic with the front mounts and a trans mount, you WILL develop numerous problems and chew up the front mount rubbers quite regularly - you really need to use the aftermarket cross member for the side mounts or fab up something similar yourself .... also I'd be inclined to use a TH400 on a 1 ton if you plan on any hauling
Bill | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | wanted to use a th400, but i got a good used jasper th350 out of my old daily driver, it works fine and it's paid for, the only thing i'm gona haul is my old harley and honda dirt bikes, and maybe pull a 1000lb pop up camper | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | do NOT try to run an automatic with the front mounts and a trans mount, you WILL develop numerous problems and chew up the front mount rubbers quite regularly - you really need to use the aftermarket cross member for the side mounts or fab up something similar yourself .... also I'd be inclined to use a TH400 on a 1 ton if you plan on any hauling
Bill 100% agreed. There's plenty of tubular style crossmembers that available that should work, and Speedway has a sidemount conversion for the engine.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | the 283 that im using is the stock motor that came with the truck, it has the mount in the block to use side mounted motor mounts just like 70-80's 350 chevy motors the truck came with a 4-speed bulldog and the bellhousing cross member that mounted it to the frame, I have removed that crossmember so that i could mount the th350 and have room for things like power brake master/booster. I don't know how much hp a 283 with edlebrock intake and 4barrel carb will make but i know im not going to drag race it! I also know that 1-ton trucks should have 4speed trannys, but auto's just make driving then so much easier I was not talking about the bell housing crossmember which should be removed for your application, but about the eng side mounting position. you must have a 3 point mounting system to counteract the force of torque from your eng, which a frt and back mounting only will not do it. even under regular everyday useage ron | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | hey longbox55 the frame mounted motor mounts that speedway motors sell look like the way to go, but the spec's on the part says that it will go from 26inch down to 18inch my frame rails are 34 inches, are all 55-59 frames the same width??? are the 1-ton and up frames different? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | All '55-'59 frames have the same width, 34".
