7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 34 New Guy | | New Guy Joined: Feb 2011 Posts: 34 | Here is the situation...My local tranny guy says he has 2 TH350's in stock.One is a "short shaft" and one is a "long shaft".He also said one is for a car and the other for a truck..so the question to all is wich one are YOU using? 1.Short/Long shaft? 2.Car/Truck model? BTW...1949 Chevy 1/2 ton..upgrade to 250I6..in process of open driveline. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | they are the same inside, just a longer tailshaft. QWere used in trucks, station wagons, big cars.Use the short one.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2011 Posts: 34 New Guy | | New Guy Joined: Feb 2011 Posts: 34 | Thanks Tommy ...I appreciate your reply and the info. Every bit of info helps since i'm new to this. Thanks again. | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | I would also choose the short shaft most of the time as it is a bit more desirable to other people if you were to change something in the future and wanted to sell it. In a pickup it doesn't matter as much, to me anyway. One variable to consider is the driveshaft length. I will usually get a used driveshaft from the junk yard and shorten it. I prefer the one piece shaft and the common lengths (cheap) might not be long enough to reach the short shaft trans, especially if you have a long bed. You might source the driveshaft and rearend before you pick the trans since you have a choice. As for which model of vehicle to source the shaft from, look for a 73 - 82ish chevy pickup, right before they put the OD in them. The splines and driveshaft yoke for a TH700R4 are the same as the TH350, but the 700R4 is longer by a couple inches. So, the longest stock driveshaft that I have found was out of a late 70’s long bed GM pickup. Hope this helps,
jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | The TH350 with the 6 inch tail shaft is very close in length to the 200-4R.
The TH350 with a 9 inch tail shaft is very close in lenght to the 700R4.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Feb 2011 Posts: 34 New Guy | | New Guy Joined: Feb 2011 Posts: 34 | Makgyver 37,Rusty Rod, squeeze, & Tommy thank you guys so much on the info and links. I knew the pros would chime in. I picked up the TH350 today from the tranny guy, $500 out the door with waranty completely rebuilt...no core needed..!! ! . | | |
