7 members (Charles in CA, dt235sd, Steelonsteel, BarryP, Wally / Montana, 37 GC, IHPWR),
143
Mod | | | Forums66 Topics128,142 Posts1,056,782 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Looking for help in removing fan blade and pulley from water pump of a 1937 chevy 216 1/2 ton pick-up.
Thanks | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The fan is easy enough - four bolts hole it on the pulley. The pulley, on the other hand, cannot be removed from the pump with any type of puller. The only way I have seen a pulley either put on a pump shaft or removed from a pump shaft is with a press. To do will require the removal of the pump from the front of the engine.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Thanks, there seems to be a collar over the top of the shaft holding the fan blade | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Did you take the bolts out? If you remove the bolts, the fan comes off. The thing you see that looks like a "cap" is the shaft of the pulley. Look at the center closely and you can see the shaft of the water pump in the center of the "cap", or shaft of the pulley. That shaft in the center of the pulley, which is the water pump shaft, is supposed to be flush with the "cap" of the pulley, which is actually the shaft of the pulley. That is the indicator of how far the pulley is supposed to be pressed onto the water pump shaft. It should be close to flush with the shaft of the water pump to be set right to line up with the pulley on the balancer. Remember, you can get the fan off, but you will have to press the pulley off of the shaft.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Thanks, Its off, and already been sent out for a rebuild. Thanks for your help | | |
