7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Good pics!!!!!!!!!! Sure could have used these bout 20 years ago. LOL HAGD Mike | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Thank you im going to go out and try this now was going to ask how the heck i moved mine LOL | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Ok i tried to get mine outis there a trick to getting the knob out i pushed in the button as hard as i could and couldnt get the knob out i pulled twisted turned all of the above??? | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Pull the knob out as if the headlights are on. THEN push the little spring loaded button in to release the shaft. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Pull the knob out as if the headlights are on. THEN push the little spring loaded button in to release the shaft.  thanks you came right out LOL i tried everything BUT that LOL | | |
