| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Are the steering wheels from a big bolt the same size as a 1/2 ton? My wheel from my 36 is 19 inches if I recall correctly... I am toying with the idea of a slightly smaller wheel but want the same look... | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Hey Corpo, I don't know about a 36 but wheel in my 55 2 ton is 18" and I beleive that is the same as the 1/2 ton. SEE YA! | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | If you don't have power steering, a smaller wheel will make it harder to steer. Just something to think about. Good luck. Jim | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | For what it's worth, WW2 Chev and GMC had at least one pattern of similar looking (wood rim, stamped steel spokes, solid hub)steering wheels in 18 and 20" sizes (I think Canadian Chev and GMC DUKW respectively but I could have it backward). Some prefer the 18" even if their truck would likely have been fitted with 20" to have more belly clearance (driver, not truck), others prefer 20" for lighter steering, still others will only settle for the "correct" size and fourth group are happy to have a good old wheel in whichever size they can get. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Thanks guys for the input...
JM Im not to worried about it being harder to steer my build is a little different but basically it will never see any sort of great weight...
Grant u wouldnt happen to have any pictures of these wooden wheels with metal spokes would you? that sounds interesting.
| | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | The photos in the link are not my steering wheels. Just as my trucks are in various states (but none finished) so are the steering wheels. One NOS, one slightly weathered but usable another with the wood fallen off but sandblasted, straightened and welded as needed and painted waiting for the new wood to be made and installed. The link shows several styles of steering wheel from about the same vintage. http://www.cckw.org/steering_wheels.htm | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | thanks again guys..! this place is always helpful
Grant.. my wheel is like the lower left the 3 spoke wheel.. (NOS early rubber wheel)
those wooden rimed wheels are really cool... ill have to keep my eyes out for one of those.. would look really nice all restored..
