2 members (DadsFirstPickup, Rusted Nut), 78 guests, and 2 robots.
Topics128,075
Posts1,056,279
Members48,441
sorry if this has been covered but i am a little lost.
have ordered a 6 lug front disc brake kit from ccp and now need to find a 6 lug 16 inch wheel/tire combo that will work well for it.
seems like there are alot of different stock rims and i want to get the right parts the first time if possible. also what are the different widths available?
thyanks alot
aubrey
I'm just getting started on a 66 Burb. No power steering will probably dictate narrow rims and tires for now. Big wide tires look neat but they are very hard to drive with no PS. And hotrod or stock?
My original rim size is 15x5.5 inch with a 6.70x15 tire. Backspacing is another issue that you need to look at. Mine was 3.75 inches.
Yours being earlier yet, will be even narrower.
Someone will pop in in a bit with some good recommendations. Someone gave me this website. Good info.
https://www.rsracing.com/tech-wheel.html
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Stock 16" wheels will work with the CPP kit with a little grinding.
saw your page on the disc upgrade I am going to keep it handy while i am installing it looks great. what rim is that a picture off of? trying to find out what width and year so i can buy a set used. i keep finding stock sets for sale with different dimensions. i guess they might be off of task force models. I am not too concerned just want to be sure that the ones i buy are the ones from your photo /project.
any tips on how to id them would be appreciated.
thanks for the help
aubrey
On any stock wheels you buy, the part that fouls the caliper will be the same as shown in the picture. The varying widths will have no effect on clearing the brake assembly. I'd recommend a wheel wide enough to accept a 215/85R16 tire.
which width works best for the 215/85R16? also i assume when you say stock you mean stock for the 51 not a later model is that correct? thanks alot for the help.
aubrey
Your '51 probably has 4" rims. I've read that some people have put that size tire on them. However the tire company charts show that to be narrow. I'd look for some wider rims from a task force truck.
Or you could do like I did and have new 6" rims put on stock centers.
right now my 3600 has 16 INCH 8 lugs. I am converting to a half ton axle in order to use the kit.
I am looking for rims for sure. any advice on where to find used task force rims in central TX? Have been told that the task force rims will be 5 inch and have three clips.i think they should work on a 215 tire and i will be able to cover up the hubs with a dog dish so that the mod is not so obvious. any advice on used parts locations would be great.
thanks
aubrey
