7 members (Steelonsteel, dt235sd, klhansen, Charles in CA, BarryP, Wally / Montana, 37 GC),
139
Mod | | | Forums66 Topics128,142 Posts1,056,782 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I have purchased a power/duel setup for my 1958 Chevy and remembered after it got here that I might need some residual check valves. The Power system will be mounted under the floor. How many check valves do I need? One for each wheel, or one for the front and one for the rear? Thanks for the help folks!
58' 3200 235 3-speed/OD
| | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | one for the front and one for the back. disks use the two lb. and drum use the 8 lb. | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Sounds good. I guess I can plumb them anywhere between the MC and the T's for the two front/back?
| | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | it should be plumbed as close to the mc. as practicle and i gave you the wrong size for shoe brakes it should be 10 lbs. i got my parts form inline tubing great selection and good prices. Hope this helps
| | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | It depends on your master cylinder. A disc / disc m/c will need a valve for front & rear. A disc / drum m/c will only need a valve in the front line. I have a m/c from a 79 Mustang in my 1949 - 3100 with drums front & rear. The stopping is much improved over the stock system, but I will be adding discs to the front later.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
