| | | Forums66 Topics128,186 Posts1,057,303 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 68 Smokey 56 | | Smokey 56 Joined: Jul 2010 Posts: 68 | Will my factory 4.57 rear hold up with a 454? I would like to keep the rear if possible. If it hooks will I break it?
Thanks for you time
Dan and Melina from MN. 1956 Chevy/GMC custom 1 Ton dually step side short box.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | It all depends on the build, transmission, tires, etc,
I believe the banjo is good for about 350 HP and 350 lbs of torque. I ripped the banjo apart in my 59 gmc 1/2 ton with a mildly built Pontiac 389. My 389 was built for about 345 HP and 450 lbs of torque.
Put it together and see if it will live. | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | 57DanR,thought I would let you know,if your rearend don't hold up,God Forbid. I have a fresh rearend,all new components,drums and all,with 8lug axles.If you need a backup,I have one. It has 456gears,it came out of a 51 Chevy 3/4ton pickup. In real good condition,I swapped to an S10 posi-trac 373 gears. I have a overdrive tranny,with 350 small block. I am located about 30 miles north of Dayton,Ohio. Good Luck,and Best regards. | | | | | Joined: Jul 2010 Posts: 68 Smokey 56 | | Smokey 56 Joined: Jul 2010 Posts: 68 | Thanks for the responses! I plan on putting a 400 auto or 700r4 with street tires on my 17" 8 lug rims.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | We used dozens of them in dirt trackers with high-HP small blocks and a few big blocks all over central California. It was not uncommon to see massive wheelspin, washboard turns, and repeated full throttle/coast cycles with no damage whatsoever, and all of this with the spider gears welded together so both wheels would hook up equally. Those old 3/4 tons are about as bulletproof as they come, just extremely heavy. We used Muncie 4-speed car transmissions in 2nd. gear against the 4.56 gearset for short tracks that measured 1/4 mile around the outside fence, and 4.10's on "long" 1/4 mile tracks that were measured around the infield perimeter. With a 1.88:1 2nd. gear against a 4.56 rear end, the overall ratio was 8.57:1. The car would come off the turn at about 3,000 RPM, and wind up to 6,500 or 7,000 by the end of the straightaway. On a 25-lap main event, the rear end got at least 50 of those RPM cycles. Counting practice, qualifying, heat races,and the main event, figure on at least 200 full-throttle accelerations and chopped-throttle turns every weekend, all summer! Yep, I think yours will hold up just fine! Jerry
