Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (GMCJammer51, 3B, Jay R), 154 guests, and 4 robots.
Topics128,274
Posts1,058,435
Members48,490
#728008 03/08/2011 8:57 PM
Here is the situation...My local tranny guy says he has 2 TH350's in stock.One is a "short shaft" and one is a "long shaft".He also said one is for a car and the other for a truck..so the question to all is wich one are YOU using?
1.Short/Long shaft?
2.Car/Truck model?
BTW...1949 Chevy 1/2 ton..upgrade to 250I6..in process of open driveline.
JC49 #728097 03/09/2011 2:27 AM
they are the same inside, just a longer tailshaft. QWere used in trucks, station wagons, big cars.Use the short one.
Tommy
59 apache 1/2t
261 short stepside
Tommy #728126 03/09/2011 4:35 AM
Thanks Tommy ...I appreciate your reply and the info. Every bit of info helps since i'm new to this. Thanks again.
JC49 #728603 03/10/2011 4:59 PM
I would also choose the short shaft most of the time as it is a bit more desirable to other people if you were to change something in the future and wanted to sell it. In a pickup it doesn't matter as much, to me anyway.
One variable to consider is the driveshaft length. I will usually get a used driveshaft from the junk yard and shorten it. I prefer the one piece shaft and the common lengths (cheap) might not be long enough to reach the short shaft trans, especially if you have a long bed. You might source the driveshaft and rearend before you pick the trans since you have a choice. As for which model of vehicle to source the shaft from, look for a 73 - 82ish chevy pickup, right before they put the OD in them. The splines and driveshaft yoke for a TH700R4 are the same as the TH350, but the 700R4 is longer by a couple inches. So, the longest stock driveshaft that I have found was out of a late 70’s long bed GM pickup.
Hope this helps,
jason
1937 GMC T16 468 BBC th350, 4.10
1941 Dodge COE 5.9 cummins, 9 speed roadranger
1947 Diamond T COE, hercules and 4 spd, all original
1955 Chevy LCF 9.0L IH diesel AT545
1962 Corvair (Elsie)
1967 Jeepster Commando
1968 K10
1970 Chevy C50 box truck
macgyver37 #730536 03/16/2011 9:52 PM
The TH350 with the 6 inch tail shaft is very close in length to the 200-4R.
The TH350 with a 9 inch tail shaft is very close in lenght to the 700R4.
Another quality post.
Real Trucks Rattle
Rusty Rod #730547 03/16/2011 10:21 PM
squeeze #731079 03/18/2011 9:21 PM
Makgyver 37,Rusty Rod, squeeze, & Tommy thank you guys so much on the info and links. I knew the pros would chime in. I picked up the TH350 today from the tranny guy, $500 out the door with waranty completely rebuilt...no core needed..!! ! .
