8 members (Oldpickupman, 41 chev, 51sub, Gdads51, Charles in CA, Nick in Manitou, TUTS 59, 1 invisible),
103
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys i have a 49 suburban that I have put on new weatherstrip, new strikers, and one new latch assembly. I can't seem to get enough adjustment in the strikers to get the door to completely pull into the body to align with the body. The strikers are up against the front 90 degree bend. Thought it might be new assembly but both doors run out of adjustment. The strikers are repops that came from Chevy Duty. Any sugestions of what might be the culprit or am I missing something?v As always help is appreciated,
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: May 2010 Posts: 24 New Guy | | New Guy Joined: May 2010 Posts: 24 | Im actually having the same issue. the one im doing is all new body work and all new components on the door. latched decent before the weather stripping but now has to be slammed to fully latch. even without the weather strip its had to be forceful to latch. maybe crap aftermarket latches?? | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | How do they compare to the original latches, if you still have them?
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: May 2010 Posts: 24 New Guy | | New Guy Joined: May 2010 Posts: 24 | well i dont have the originals anymore unless i gave them back to the owner. this first build of mine is a true learning lesson on what to do and what NOT to do hahaha | | |
