0 members (), 83 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
My '64 GMC longbed stepside must have had a leaky battery sitting in it at some point. There was likely some sort of hose explosion too from the surface rust on some of the other parts as well.
I got the battery tray removed, and of course one bolt was seized and had to be reminded who was boss. smile There were a couple of nasty pieces of wood under the battery, and the bottom of the tray was nearly eaten all the way through.
I could just buy a new one, but what fun would that be? So I tried my hand at electrolysis rust removal. I used a motorcycle battery charger, and next time I'll put the battery in between the charger and the electrolysis rig for safety.
Anyway here are the pics. As I complete the tray I'll post updates.
http://captaincheeto.com/pictures/64-gmc/batterybox/
There is one place that you have not looked, and it is there - only there - that you shall find the master.
I'm supprised it worked that well. I have never tried it, but that looks pretty good.
I'm trying to calulate how many gallons and how long, just to dip the whole Burb.
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
I have a pool, and I've been eyeing it. smile
The center section on the underside of my hood has a big spot of surface rust too. I may pull it off, flip it over, and fill it with water and try this on it. That would really excite me to get that one cleaned up. If I do it I'll definitely get pics of it.
