| | | Forums66 Topics128,167 Posts1,057,096 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,741 24601 | | 24601 Joined: Nov 1995 Posts: 5,741 | Got the engine running again and timed almost correctly. New issue is that I seem to have a hole in the passenger side of the block, slightly above the oil level inside the block and located below the Number Two cylinder (right behind the alternator, under the fuel pump). The hole is threaded. When the engine idles, no oil comes out. When the engine is gunned or idles high, oil splashes out.
Apparently, I seem to have lost whatever it was that went in this hole.... What was in this hole? I currently have a short bolt threaded into it to keep the oil in but am not sure if this is a good idea or not.
Anyone know what this is and what I need to put back in that hole?
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | John, you know better by now... Where are the pictures??
Grigg | | | | | Joined: Nov 1995 Posts: 5,741 24601 | | 24601 Joined: Nov 1995 Posts: 5,741 | I painted you a mental picture ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I see the picture. Looks oily and the rocks below the truck are wet. See? | | | | | Joined: Nov 1995 Posts: 5,741 24601 | | 24601 Joined: Nov 1995 Posts: 5,741 | Hambone -- maybe they would like to show me a picture of how we're supposed to get a camera down in there ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Maybe drop the engine. Open it up and take a picture from the inside. I guess no one has any ideas on its purpose. | | | | | Joined: Dec 2010 Posts: 34 New Guy | | New Guy Joined: Dec 2010 Posts: 34 | I think it would be too weird for it to be an accessory mounting hole, so could it be a plug for the oil galley? Is it pipe thread or SAE? Do you have good oil pressure with it open / closed?
46 Chevy 1 1/2 ton
| | | | | Joined: Nov 1995 Posts: 5,741 24601 | | 24601 Joined: Nov 1995 Posts: 5,741 | . It is in a weird and very inaccessable place. It just might be a simple plug as I see no difference in the oil pressure between it being open and with a 7/16 bolt stuck in it. It probably is pipe thread as the SAE bolt didn't seem to fit quite right.
Thanks for the ideas!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it's a pipe thread and you've managed to get a 7/16" bolt in it it surely didn't fit well, to much difference in thread pitch for any possible combinations that might sort of fit.
Try an 1/8" pipe plug, see if it fits nicely?
Grigg | | |
