3 members (3B, Otto Skorzeny, Gdads51), 165 guests, and 3 robots.
Topics128,091
Posts1,056,387
Members48,442
Are the suburban and truck floors the same im looking into replacing my floors and noticed what i think are some defferences in what is offered aftermarket i know the suburban pass seat has a dip where the back bar of the seat sits in. So can someone point me tot he right direction here please thanks
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
How much floor to you plan on replacing? The floors from the trucks were also used in the panel and suburban with modifications. The seat riser is different in all three, the suburban has a steel plate attached to the floor so that the jumper seat will sit flat. The after market replacement pieces will fit in all three. The entire floor that is available from many vendors will fit in all three, with a slight modification for use in a suburban and panel. The rear of the floor pan has been modified so that it will attach to the rear floor/plywood.
complete floor for pickup To fit the suburban and panel you must remove the section where the gas tank fits. You will have to remove the seat riser too.
There is one more style of panel, actually the first style of replacement panels that did not include the toe board, either left or right side.
Originally Posted by GMONIZ
How much floor to you plan on replacing? The floors from the trucks were also used in the panel and suburban with modifications. The seat riser is different in all three, the suburban has a steel plate attached to the floor so that the jumper seat will sit flat. The after market replacement pieces will fit in all three. The entire floor that is available from many vendors will fit in all three, with a slight modification for use in a suburban and panel. The rear of the floor has been modified so that it will attach to the rear floor.
This is what my pass side floor borad looks like now
http://i89.photobucket.com/albums/k237/bigtony55/IMAG0193-1.jpg
http://i89.photobucket.com/albums/k237/bigtony55/IMAG0195.jpg
http://i89.photobucket.com/albums/k237/bigtony55/IMAG0194-1.jpg
http://i89.photobucket.com/albums/k237/bigtony55/IMAG0196.jpg
http://i89.photobucket.com/albums/k237/bigtony55/IMAG0198.jpg
Stovebolt CHEVROLET
MY 1949 SUBURBAN
Although that plate does not look original, it can easily be removed and a new plate can be installed. You may have more rust underneath that panel that may need to be removed.
Did suburbans have plates like that or more of actual floorboards?
Stovebolt CHEVROLET
MY 1949 SUBURBAN
The plate covered an area that started at the rear of the riser and extended just beyond the riser. It was about and 1/8" I will look for some pictures.
Stovebolt CHEVROLET
MY 1949 SUBURBAN
George,i will also be waiting for the pictures.My plate is sheet metal,I think it's about the same gauge as the floor pan.It looks to be original,but not sure.I've posted a picture of it here in the past.
Tim
1951 3100 Chevrolet
I'm quite certain my floor plate is original. Here are a few photos. they aren't the greatest, but here they are.
http://gallery.mac.com/patrick.plummer#100287/IMG_0379&bgcolor=black
http://gallery.mac.com/patrick.plummer#100287/IMG_0369&bgcolor=black
There's an older thread out there where we've discussed this before
I took the riser out of mine and replaced the floor. It is all flat metal with a few beads rolled into it for strength now with late model suburban buckets.
PRETENDING IT'S BROKEN SO I CAN PLAY IN THE GARAGE.
