| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 47 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 47 | hi guys. i hooked up a voltage reducer between the ignition and my heater on my 50 chevy. the volt reading before the reducer and after the reducer is just below 12 volts. shouldn't it read 6 volts after the reducer. i couldn't find an answer searching the forum although i'm sure it's there somewhere. thanks.
Che 1950 Chevy 3100
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are using a two terminal device, it will read 12 volts on both sides when the heater motor is not running. It needs a load before dropping the voltage. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks truckernix, I was working on the same thing today and wondering about that. Man, this is a great information source!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | The voltage drop across the reducer will change according to current flow. It's just a high-wattage wire-wound resistor in most cases. For instance, if a circuit that draws 10 amps gets reduced to 6 volts applied to a heater motor, etc., you would need a 0.6 ohm resistor with a 60-Watt minimum capacity. The resistor would consume 6 volts, and allow the other 6 volts to be applied to the heater motor. If the amperage changes, the resistance has to vary accordingly. Once the charging system kicks in and the available voltage goes up to 14.5 or so, all the calculations change. I like to use big wire-wound resistors with a sliding center tap so I can fine-tune the voltage for actual operating conditions, not some "one size fits all" voltage reducer. Jerry
